Leak under the kitchen sink
Posted by AL on September 03, 2002 at 15:49:37:
There is a leak under my kitchen sink that occurs when the dish washer is draining or when youfill the sink with water and then drain it. I have determined where the leak is coming from. There is a hose that goes from my dish washer to the wall and there is a valve closest to the wall (it is a shut off valve from what I am told. The water leak is not coming from the hose or the valve but from the round plate that is between the valve and the wall. I can actually pull the valve and the plate comes away from the wall. Will sealing the plate back to the wall stop the leak and if so where is the water coming from inside the wall?
