| Posted by hj on September 03, 2002 at 07:52:41: | |
| In response to Re: how much is too much (plumbing rates)? | |
Average labor rates are whatever is common in your area, with the possibility of finding some plumbers very much below that and some a lot higher. You do not have 1' pipes in your house. 4" maybe, but that would be the largest unless it was built by someone who had a lot of money to burn. YOu may have to have a plumber check the toilets since units from that era normally flush properly. They do not wear out but can need tune ups. : We just moved in a few months ago. The house is in good shape, built in 56. but,we use the plunger on our two Titon 1.6's about 2-3 times per week. Embarrassing when the in-laws come over and even her grand-ma's gotta use a plunger. So I'm researching what to do next, replace the toilet, check out the drains, etc. : 1) Labor charges: how much should I expect to pay for a decent plumber (Atlanta, if that matters....) to inspect the problem : 2) Most of the plumbing is new, to the main drain that runs under the house, which is a huge ugly pipe. The HVAC guy that checked out my furnace in the crawl space said something along the lines of "don't see much of that plumbing anymore" and he gets under houses a lot more than I do teaching high school... : or should i just get some pressure assisted toilet and i'll be fine, and grandma can flush with ease (or should i be asking my wife what she's been feeding g'ma?) : john martin
