| Posted by hj on September 01, 2002 at 09:40:58: | |
| In response to Re: shower door rubber seal replacement | |
Most of the readily available replacements slide between the channel and the door and are held in place by the screws holding the channel. A proprietary seal such as you describe is normally only available from the original manufacturer. : I nedd to find a replacement rubber seal for the bottom of the shower door. The door is an aluminum frame with a screwed on drip channel on the inside of the bottom of the door. The rubber seal slides into a track on the bottom of the drip channel. Any idea where I can get eight or ten of these rubber seals? If I need to I would consider buying the drip channel with the rubber seal already attached.
