| Posted by Kevin on August 29, 2002 at 22:03:09: | |
Am installing new bathtub and found old brass drain where tail pipe connects corroded badly and encased in some sort of tar substance. Further digging under slab revealed a cast iron p-trap connected to a cast iron main drain line utilizing a fernco type fitting. Want to replace entire trap assembly(half plugged with buildup) and brass line leading up to where the new tailpiece will slide in. Any suggestions on materials and methods. Thanks...... |
| There are none. |
