| Posted by Charlotte on August 28, 2002 at 15:27:21: | |
| In response to Re: Smell from shower drain | |
: It is a tile shower (floor, walls, ceiling all in tile) : If this is a cultured marble (assembled) shower and base, then the most common cause is that the floor has come loose from its concrete underfloor and water and soap have gotten under it and gone foul. When you walk on the base it flexes and pumps the "rotten" water out giving the odor. If you have any other kind of base, that would not be the problem and something else is happening. : : When taking a shower there is a strong urine smell coming from the shower drain, gross! Only one shower in our house has this problem, what is the cause and how can we fix it?
| There are none. |
