Re: replacing galvinized pipes
Posted by hj on August 28, 2002 at 01:10:10:
In response to Re: replacing galvinized pipes
PIping on a flat roof will freeze, even in Phoenix, and even though insulated. For flat roofed houses, I prefer to run the pipes around the perimeter under the eave where they are more protected from cold winds and receive some heat from the house. I have usually convinced the insurance companies that it is cheaper for them to pay at least a portion of the repipe than to pay multiple damage claims when leaks occur. It usually works unless you have Allstate Insurance.
: I am in Tucson and I am learning more and more each day. I have a flat tar build up roof. so they said I can even go copper on the roof and insulate it. My reference to going overhead is wrong. I think they were refering to the hot water heater relief valve. Oops
: My inshurance company is not wanting to pay for any of the repair. So this is slowing things down, except for showers with only cold water those are fast! Thanks MKM
: : Which part of AZ are you in? Around here that is about the only way PEX and CPVC is installed.
: : : Thanks for the response. I was wondering between PEX and CPVC? I am checking with the codes, but I have been told here in AZ I can not go overhead. I will find out. CPVC glues together, correct? How are the fittings attached with PEX? Do they have fittings for either to attach to the existing galvinized plumbing?
: : : : Copper or PEX plastic are the two most common materials. It would be difficult to install the new piping under the concrete without making a lot of holes. The repiping is normally done with the new pipes overhead in the attic.
: : : : : I have a home built in the 50's. I have a major slab leak(hot water). It is all galvinized and is in horrible condition. What is the most widely used and recomended material used to replace galvinized pipes? I have gained access to the plumbing through holes jackhammered in the slab. Thanks MKM
Replies to this post
