| Posted by hj on August 28, 2002 at 01:02:09: | |
| In response to Re: Q: WaxGasketInstall = onto bowl first OR onto flange first??? | |
IF you can get it to stick while you position the bowl then you can attach it first. Usually it is easier to set it on the flange and place the bowl on it. If you do not set the bowl properly the first time, you can still damage the wax ring doing it this way. : hi .... this is a Great site! : Question about instlling the Wax Gasket for a : Is the Wax Seal supposed to be pressed onto the : I've just tried it myself with wax on toilet's exit : Any hints??? : any info would be appreciated!!! : Regards,
| There are none. |
