| Posted by hj on August 27, 2002 at 08:54:20: | |
| In response to Re: no water from hot tap | |
THe logical place to start would be the water heater. ANd specifically the shut off valve to it. If it broke and the gate dropped into position it would allow some water to flow around it giving the symptoms you describe. : The water has stopped running from our hot taps. The cold runs fine. If you open any hot tap in the house all you get is about 3 seconds of air gurgling out and then nothing. Any ideas please.
| There are none. |
