| Posted by lisa theorle on August 26, 2002 at 20:06:24: | |
| In response to Re: Dishwasher leak! | |
Found the problem. The seal around the soap dish door assembly leaks. Fix it with silicone caulk. : : My seven-year-young ever-so-nice dishwasher has sprung a leak. : Lis, : Same problem here. I replcaed the seal at the bottom of the door, but having done so, I do not believe the seal is the prblem. I believe it is associated with the water level cut-off switch or associated mechanism. : More research required yet as I do not uuuuunderstand how it all works. : Will post again if I find a solution. : tony
| There are none. |
