| Posted by Brian Dennis on August 26, 2002 at 14:34:51: | |
| In response to Re: Pressure assisted toilets | |
Bill: I recently bought and installed a Gerber Ultra Flush in my home and I cannot recommend it enough. Pressure range for unit is 20-80 psi. I suspect my city pressure is 40-50 psi. Refills and pressurizes in less than 10 seconds. Works great and no sweating tanks which turned out to be a bonus. Good luck. : I would like to replace an old toilet with a new Gerber pressure assited toilet. The question I have is since the pressure is built back up after the flush by the water pressure, how much water pressure is required to 'refill' the tank? : My concern is that I live in a rural area with spring feed water (great stuff) and use a pump to gain pressure. My peak pressure is approx. 50psi so I want to be sure that it will refill the toilet. : Thanks ahead of time for your help.
| There are none. |
