| Posted by Jeff on August 26, 2002 at 10:06:54: | |
I recently replaced my water pump and have noticed a decrease in water pressure. The old pump had the pressure switch set to 40 - 60. My new pump is set at 30 - 50. Do I just adjust the pressure switch to 40 - 60? Is it true the holding tank pressure should be 2 psi less than the "on" pressure setting? |
| There are none. |
