| Posted by hj on August 25, 2002 at 09:14:59: | |
| In response to Re: replacing galvinized pipes | |
Copper or PEX plastic are the two most common materials. It would be difficult to install the new piping under the concrete without making a lot of holes. The repiping is normally done with the new pipes overhead in the attic. : I have a home built in the 50's. I have a major slab leak(hot water). It is all galvinized and is in horrible condition. What is the most widely used and recomended material used to replace galvinized pipes? I have gained access to the plumbing through holes jackhammered in the slab. Thanks MKM
