| Posted by david on August 22, 2002 at 12:30:59: | |
| In response to Re: pipe noise as washer turns on | |
: I've read posts about the water hammer noise as an : appliance or faucet is turned off, but I'm having a : similar problem when the clothes washer turns on. : As the water is turned on, there is a loud bang coming : from the pipes in the wall. The noise sounds like it : is at/near the water heater (which is near the washer). : The noise does NOT happen when the dishwaher turns on, : or if a faucet is turned on. What is the cause? How : to fix it? : Thanks. There is a soleniod valve on the washing machine that closes fast and har creating a shockwave in the pipes. There are devices available to elivate this. The absorb the shock. |
| There are none. |
