| Posted by Dan on August 21, 2002 at 11:14:49: | |
I am running a water line from myhouse to my new barn but the line will not go inside the barn. It will simply stick up on the outside of one end and be attached to the siding. The line runs downhill from the house and can be shut off from up there but I am concerned that, in the winter, even if I shut it off at the house and let the line flow through the barn faucet, not all water will be removed because of the last several feet where the line goes from 3' underground to ground level. Is there a special faucet that sticks down into the earth 3' or so that can be attached to the barn or do you have any other specific advice on this? Thank you. Dan |
