Woodford Model 14 Frost Free Faucet
Posted by Gerald Repasky on August 20, 2002 at 12:17:24:
How do you remove the stem after the packing nut is removed ? It doesn't want to pull out ? Is there a trick to removing the stem ? Is it necessary to also remove the packing and the packing washer ? Is there a pin in the stem that you have to line-up ?
Replies to this post
There are none.
