| Posted by hj on August 19, 2002 at 23:50:31: | |
| In response to Re: anti-siphon valve problem | |
If it were not partially plugged or otherwise obstructed the water from the dishwasher would flow down to the disposer when the DW was draining. Since it is overflowing the water cannot drain properly, which means it is either plugged or not installed properly. : : The anti-siphon valve from my disposal spews water whenever the diswasher is draining. Any clues as to what might be the problem? : Its not plugged. What's the solution. What is it that I can do? Detailed information would be appreciated. I'm desperate. : Thank so much. : Sheila
| There are none. |
