| Posted by Jim Lohman on August 19, 2002 at 17:20:47: | |
I recently installed a corner shower kit with two stationary glass panels coming out from the walls at 90 degrees and a diagonal door panel that joins them in the middle. I have used that flexible vinyl tape that has putty on one side at all 90 degeree surfaces plus silicone along the edges of that and all glass to frame points. I still have one are of leak in the bottom of one of the corners where the panel meets the wall and the shower base. The silicone seems to want to peel of very easily also. Well cleaning the surfaces with alcohol do the trick? What is the best type of clear silicone to use please. I have been fighting this for months. Kind Regards Jim Lohman |
| There are none. |
