Re: leak in copper plumbing
Posted by Gary Swart on August 18, 2002 at 19:11:15:
In response to Re: leak in copper plumbing
As I pointed out, finding the leak is the hard part, fixing is easy. Apparently you know the leak is in a wall. I'd just tear the entire wall covering off and not try to save any of it. It's just as much work, maybe more, to patch a hole. If it's an outside wall, the insulation is toast anyway and the wall likely has some damage too. I think you just have to get the mindset that this isn't going to be a minor patch job, but replacing sheetrock shouldn't be an overwhelming job. Let's face it, the leak has to be found and fixed. With any luck at all, you'll find the leak in the first wall you tear into.
