Re: Drain stub-out relocation
Posted by Gary Swart on August 17, 2002 at 13:15:19:
In response to Re: Drain stub-out relocation
Just a quick additional note. Make turns as wide as possible. Long sweep elbows rather than short, sharp corners. If you have access to the drain in the crawlspace, I'd consider making the adjustment there and having a straight shot to the sink. Use as few bends as possible and make the ones you need as gentle as possible.
Replies to this post
There are none.
