| Posted by hj on August 15, 2002 at 00:51:03: | |
| In response to Re: sanitary tee | |
A toilet is an "S" trap and would not flush without it. If you are trying to "flush" the sink, and have a means to automatically refill the trap, which a toilet does, then an "S" trap would be okay. You aren't and you don't so "S" traps and the 3/4 S variation are illegal. The theoretical maximum trap arm is the diameter divided by 4, after that you get back to the 3/4 S configuration. The legal length is usually less than that to avoid hair splitting. : what if I have a substantial trap arm that is connected to the sanitary tee? I was told that the requirement had something to do with the maximum trap arm length that was allowed in the plumbing code, but I cannot find anything to back that up. why is the "S" trap illegal? isn't that the kind of trap that is in the toilet? is there a definitive reference that someone can put me onto? thanks : : : why do some applications require the use of a santiary tee as opposed to a tee wye? I can see they are different but why are they different? when connecting a trap arm to the vertical, you need a sanitary tee and not a tee wye.
