| Posted by hj on August 13, 2002 at 23:19:20: | |
| In response to Re: Kenmore 12+ miser electric water heater Overheating | |
If you had tested the elements first you would not have wasted money replacing the thermostats. The elements are burned out if you have 120v between the terminals at any time. : I have changed both hof my thermostats anad my water temp still overhheats to scalding and leaks out of the temp relief valve? What else can this be? Even when the temp is very hot thhere is 120v on each hheating element?
| There are none. |
