| Posted by hj on August 13, 2002 at 23:17:34: | |
| In response to Re: sanitary tee | |
If you connect a trap branch with a combination Y-1/8 bend, you create what is called a 3/4 "S" trap. Any "S" trap is illegal. They are different because certain applications require the sweep of the combination fitting. : why do some applications require the use of a santiary tee as opposed to a tee wye? I can see they are different but why are they different? when connecting a trap arm to the vertical, you need a sanitary tee and not a tee wye.
