| Posted by Gary on August 11, 2002 at 18:34:38: | |
| In response to Re: Toilet flange height | |
Most often you set the flange after the tile has been laid,,,it's good and tight to the floor this way..If this is not possible you should measure the thickness of the tile and set the gap between bottom of flange and existing floor to this height.
| There are none. |
