| Posted by Dave on August 11, 2002 at 04:30:29: | |
| In response to Re: Recirculating Pump Probs | |
I didn't see any shutoffs. I ended up having to hire a plumber due to a lack of assistance online.
: : : We are now having the same symptoms. It takes about 3 or more minutes for the water to get hot. This just started a few days ago. : : There appears to be a control panel and/or power supply connected to this pump. The power light is on. It says Goldline on the controls. : : I was recommended to cut the power supply line from the pump to the control panel and put a plug on it. Then plug it in and see if it works. : : I went today to buy a plug. I hooked it up the best I can, but I was unable to fully pull the cover over the prongs. The wires get in the way. I plugged it in to check for power, but nothing happened. : : I need help to make sure I am hooking the plug up correctly - then to confirm that the pump is not working. If not, I need a recommendation on another brand, so I don't have to go through this again in 2 years. : : I can send digital pics detailing the situation. : : Thank you.
| There are none. |
