| Posted by Patricia Whitney on August 10, 2002 at 22:49:48: | |
| In response to Re: DWV system | |
I forgot to mention that according to my neighbor who has been here all her life, this home was built by an individual ( as in no contractor involved.) I am aware that many thing are not up to current code, but they may have passed at the time of construction. My kitchen sink and washing machine all drain straight to a ditch, with no septic or sewer system in between. T. : Okay, I can certainly go along with the idea that it could be another problem, but I don't know where to turn. As stated, a plumber has been here twice. This plumber was maybe 22 years old. His "fix" of installing a new toilet did not fix the problem. Today he decided that it must be a main line problem, but immediately corrected himself and said my private sewer system (called a mo-dad) must be 'Full." When I called the mo-dad folks, they asked if my access valve had a "rotten egg" smell, it doesn't. It smells fresher than the air in my home, quite pleasant. I have never had aproblem with this system. The mo-dad agent said it sounds like a vent problem. I am eager to get to the bottom of this as the lack of a real flush has been going on for 5 years (since we bought the house.) While I appreciate the response, I am still curious about the answer to my question. How does one access the proper vent line when it is within the walls? I only ask because I would like to be prepared for what the next plumber suggests, and tearing out the walls sounds very expensive. I only have one vent through the roof for both bathrooms. : Thanks again, Trish
: : : I am certain based on info from these boards that I have an obstruction in my toilet vent. I found a diagram that you put into a thread that showed how the sink, toilet, and tub vents are joined together within the walls before exitting through the roof. Since my tubs, sinks, and one toilet are operating fine (I have back to back bathrooms), I assume that I may have a blockage in the portion of vent that runs to the toilet with the problem. I have all the symptoms of a vent problem (glurping sound, illusive lazy flush even after replacing the toilet.) My question is this, how does a plumber access the correct line without tearing out the walls? I have already had a plumber here, TWICE, but am now convinced he doesn't know how to fix it, even after I offered the vent as the problem. Frankly I am "plumber shy" after paying the last guy $315.00 for a toilet I likely didn't even need. I have indicated the diagram you previously gave in the optional link URL space below. : : : Thank you for your assistance. This is a wonderful and well planned website. : : : Patricia Whitney
