Toilet Bowl - Water Level
Posted by Lynne on August 10, 2002 at 16:20:54:
We haven't had anything done to our toilet in years, so no recent repairs that would be causing the problem. After flushing, the water level rises up to where it should be. Time passes (hour or so) and the water level is much lower--lately it has gotten to the point that there is only about an inch of water in the bowl. I don't believe there are any obvious leaks and we are prone to low water pressure (if you flush the toilet and run the sink water at the same time you can see a slight decrease in the flow in the spigot).
Replies to this post
