| Posted by hj on August 10, 2002 at 09:48:56: | |
| In response to Re: kohler pressure toilet leak | |
First call Kohler to see if that was one affected by the recall. If not, then a local Kohler dealer will have, or can get, the part. : I have a 7yr old kohler pressure-clean toilet that has begun to lose it's pressure. On inspection, I've found water spray coming from the "plunger-post" when the toilet is flushed - this is the valve assembly located in the circular section in the center of the pressure tank. This recessed area also is holding water and I've noticed air(water)escaping from the ring which surrounds the recessed hole where the valve is seated. It appears that there are very small pinlike holes or cracks in this ring, which I believe may be a threaded part to hold the valve in place.? I don't really know of course and the plumbing store where I bought this from was no help. Has anyone had similar problems? Any ideas on locating parts for this product and repair instructions? Thanks for any help.
