| Posted by Gary Swart on August 08, 2002 at 00:19:54: | |
| In response to I stand corrected! | |
: Since pipe is usually screwed together, refering to it sweating usually means there is condensation on it. Sweating copper tubing is a soft solder process. Silver soldering is a brazing operation which also involves the missibility of the media into the joint, but at a much higher temperature. : : WHATS THE DIFFERENCE BETWEEN SWEATING PIPE AND SOLDERING PIPE COPPER SILVER SOLDER.
| There are none. |
