Re: Toilet with triangular tank
Posted by hj on August 07, 2002 at 09:04:52:
In response to Re: Toilet with triangular tank
Eljer still makes the Triangle. You can check with an Eljer dealer to see if the Triangle tank has the same mounting arrangement as the handicapped toilet. If so, you can buy the tank and bowl separately and put them together. Purchasing them this way usually costs a bit more than if they were purchased aa a unit, but it should work for you.
: I am looking for a toilet with a triangular-shaped tank to fit into a corner. It must also be ADA rated. I understand that Eljer used to make one called the Triangular Ultra, but I don't think they make these anymore. Can you direct me as to where I can find purchase info for a toilet with a triangular-shaped tank?
: Thank you
Replies to this post
