Re: Mixet
Posted by hj on August 07, 2002 at 00:29:47:
In response to Re: Mixet
The pipes in the wall are reversed. On a mixet, you just put the handle on backwards aand rotate it to the proper orientation. If you have a Moen valve you remove the handle and rotate the stem 180 degrees. On some Deltas, you rotate the entire cartridge. (some Delta valves cannot be reversed).
: Several years ago I had to replace a Mixet valve for the obvious reasons. I've had no cross over or mixing problems since, BUT the Hot and Cold are reversed. I even bought another valve by another manufacturer and it's the same. It didn't used to be that way. Thanks for any suggestions?
Replies to this post
There are none.
