| Posted by Roxey on August 06, 2002 at 18:28:35: | |
We have a pop up bathtub drain that has, in the past, been clogged. Have found the screw to remove the metal stopper and pulled the clog out; water running fine. Esthetic problem now! Previous use of declogger has corroded the plate on the bottom of the bathtub into which the stopper drops. How do I remove that section to replace same? |
