| Posted by SEAN on August 06, 2002 at 16:53:48: | |
i hv a cold water cut off valve under my bath sink that constantly leaks. the house is built in 69 and i think its been in there since then. is there some sort of gasket inside the valve that needs to be replaced ? maybe a bolt that has came loose ? or should i just pull and replace the entire valve. thanks sean |
| There are none. |
