jacuzzi pump pressure is low
Posted by Phil Bavaro on August 01, 2002 at 21:56:56:
I have a jacuzzi bathtub and the pressure coming out of the jets has diminished to about 1/2 the normal pressure over time.
I've tried everything short of disassembling the pump and checking out the impeller. All the piping seems to be clear when I stick a hose into them and turn the water on.
When the pump is working, if I block three of the six jets, the pressure still does not seem to get back up to the normal pressure.
So I expect that I have to unbolt the pump from the vibration mounting, unbolt the impeller housing, twist the two large pipe unions off, and separate the pump to impeller part of the motor.
Any comments?
Replies to this post
