| Posted by hj on August 01, 2002 at 09:11:50: | |
| In response to Re: whats needed for multi shower head | |
The only requirement is a lot of water. The only way to tell the size of the pipe is to look at it, but normally it will be 1/2". The water flow is a function of the size and configuration of the valve, not whether or not it is thermostatic. : I am so confused about the requirements for having two shower heads be on at the same time with adequate water flow through probably half inch pipe. (Btw, what is the easiest way to determine if one has half inch or three quarter inch pipe?) : Is it true that getting a thermostatic valve only helps in maintaining temp and wont help with providing adequate water flow to two heads? : Thanks for your advice
| There are none. |
