| Posted by Doug on August 01, 2002 at 07:00:52: | |
I am so confused about the requirements for having two shower heads be on at the same time with adequate water flow through probably half inch pipe. (Btw, what is the easiest way to determine if one has half inch or three quarter inch pipe?) Is it true that getting a thermostatic valve only helps in maintaining temp and wont help with providing adequate water flow to two heads? Thanks for your advice
