Re: Floor Drains
Posted by hj on July 30, 2002 at 00:27:53:
In response to Re: Floor Drains
If you put in a separate drain system and terminate it outside the house, above ground you would not need trap primers, (or traps either).
: I would like to have floor drains in the mechanical room (water heater TPR outlet and water heater maintenance) laundry room (washing machine) and the kitchen below the dishwasher.
: If these drains tie into the main DWV systems they would need trap primers - my sense is trap primers are potential sources for problems (all drains are in the concrete slab. My preference is a seperate drain system. Suggestions???
: Thanks, Fred.
Replies to this post
There are none.
