| Posted by Dale's Plumbing Service, Inc on July 29, 2002 at 16:58:01: | |
| In response to Re: Floor Drains | |
: I would like to have floor drains in the mechanical room (water heater TPR outlet and water heater maintenance) laundry room (washing machine) and the kitchen below the dishwasher. : If these drains tie into the main DWV systems they would need trap primers - my sense is trap primers are potential sources for problems (all drains are in the concrete slab. My preference is a seperate drain system. Suggestions??? : Thanks, Fred. Fred, If you are under a plumbing code that is enforced ,your preference doesn't matter.A trap primer is good because of the fact that the traps will dry up if there is not a constant usage at least 3 times a week. Of course you must use the trap primer to get the effect out of it.Maybe you could put it on a clock and let it do its thing automaticly. |
| There are none. |
