| Posted by Dale's Plumbing Service, Inc on July 26, 2002 at 19:06:30: | |
| In response to Re: Submersible Pumps Pressure switch clicks continually | |
: We put in a new holding tank and a new pressure switch. When we put the water on the switch continually clicks. Either your tank has a plug in it or your pressure switch needs adjusted. do not have a valve between the tank and pump. If you do make sure it is open!!Make sure the tank is at least a 30 gal. smaller tank will work but it will cause the pump to work harder.
| There are none. |
