Re: Well tank pressures SEE Below June May
Posted by More on July 26, 2002 at 01:59:22:
In response to Re: Well tank pressures SEE Below June May
Look at this same question asked in June May April posts by going to the bottom of this page . Heres a June copy: In Reply to: Water pump and presure tank posted by Mike on June 13, 2002 at 11:14:21: What problem remains? The pump runs 24 hours and gets hot and blows a breaker? If the tank holds pressure, the pump should shut off as soon as it reaches the 40 pounds. If it doesn't shut off, then you need to adjust the high pressure side of the limit switch. If the small tank doesn't show 8 to 12 pounds of steady pressure,then the main tank is bleeding water through the small tanks diaphragm. Replace it. : I recently got elected to take over the maintenence of the irrigation pump set-up for our neighborhood association. It draws water out of an irrigation stream and is pumped to a faucet in each homeowners yard. It consists of a control box with overload breakers and fuses, a pump, one small presure tank mounted to the top of the pump and one large presure tank. Each fall the system is drained and shut off until spring. The large tanks bladder had broken a couple of years back, so it was a weekly chore to keep it aired up. This spring when I fired it up it would run about a day before quiting. The breaker would be blown and all presure in the big tank would be gone. I found a hole in the tank and replaced it. The problem remains. (although now the tank maintains air presure) Could the pump itself be the problem? : Could the breaker have gotten weak? : How much air presure should the small tank have? (the large one has 18lbs per instructions) : The pump is set to start at 20lbs and stop at 40lbs. : Any help would be appreciated.
: I would like to know what pressure wells typically run at - on&off pressures and what would be concidered maximum pressure settings. I posted this once before but it either got lost in the "missing messages" post or my computer skills need tweeking. More than likely the latter case. : Al W.
Replies to this post
There are none. |
