| Posted by hj on July 24, 2002 at 23:53:37: | |
| In response to Re: Tile around toilet | |
If you tile to the toilet and have to replace it someday, you will have to revise the tile, since you will never find another toilet that will fit the hole left when the toilet is taken up. Also, if you have to remove the toilet because of a stoppage, you may damage the tile or break the toilet. : When installing a new ceramic tile floor should I bring the tile to edge of the toilet or can I bring the tile to the edge of the drain pipe and set the toilet on top of the tile?
| There are none. |
