| Posted by hj on July 22, 2002 at 23:49:01: | |
| In response to Re: Rim mount Amer/Standard tub Stratford | |
YOu can mount it on the tile, under the tile, or you can tile up to it. Unless you have a sturdy platform you will still want to support it under the bottom of the tub, anyway, since any movement will damage the tile grout regardless of how you install it. : Anybody ever install one of these A/S Stratford tubs ? It mounts on its rim, and not at all on the sump. My question is, do you mount it on top of the finished tile surface, or do you mount it on the cement board, and then tile up to the edge ? I'm thinking if you mount it onto tile, the weight might crack it.
| There are none. |
