Re: sewer drain
Posted by hj on July 21, 2002 at 21:56:19:
In response to Re: sewer drain
if you mean actually in the slab itself, then some inspectors will refuse it because they may feel it will weaken the concrete and crack at that point. It would be more likely to happen if there is a material around the drain line that both makes the void bigger than if it were just the pipe and more likely to crack because the material would be flexible.
: Can I put a sewer drain in a concrete slab?
: If so, what do I wrap it with?
Replies to this post
There are none.
