Re: American Standard overflow problem
Posted by Ed on July 16, 2002 at 22:19:54:
In response to Re: American Standard overflow problem
I just got the AM Cadet and I'm having the same problem. I had the tank replaced and the problem still persists. I have yet to use this toilet. I'm really disappointed with American Standard. : Terry, : My American Standard,6.0lpf/1.6gpf toilet will not shut off. The yellow refill mechanism in the toilet is not working. The yellow casing contains two soft plastic washers and a silver dollar size hard plastic piece which also connects to a hard plastic tube (length of a pencil).In the past, I removed the internal parts and soaked them in vinegar to remove calcium deposits. The vinegar trick is not working anymore and I'm getting frustrated with always having to stop the water flow thru the valve below the toilet. I went to Home Depot and Lowes for advice and walk away with no new ideals. I need help big time.
Replies to this post
There are none. |
