| Posted by mickey on July 08, 2002 at 22:11:52: | |
| In response to Re: Repairing leaky frost proof sillcock | |
: I assume that if the outside faucet keeps dripping after I turn the handle off, I need to replace the washer, and if it leaks from the faucet sillcock body when the valve is open (like when connected to a hose) that I need to do something with the packing nut and the packing. : I took off the handle and the packing nut, but I can't get the stem to budge. What are the steps for removing the stem, changing the washer, and replacing the packing? I don't want to make it worse. : : I am in the same situation. I can't get the stem to budge and I don't want to try too hard because I don't want to make a bad situation worse. What advise did you get, Gene or Bob????
| There are none. |
