Re: water softner and potassium chloride
Posted by More on June 30, 2002 at 23:44:58:
In response to Re: water softner and potassium chloride
Test the water in the septic tank for ph. If its higher than 8 its too high, if its lower than 6 its too acid, for normal breeding of aerobic and also anerobic bacteria in the septic tank. In that case check the sludge and scum in the bottom of the primary and secondary compartment. If there's four inches in the primary and zero in the secondary, you're okay for two years. Pump it then. : Can anyone tell me if potassium chloride from from my water softner is hurting my septic system. I have a mound system.
