| Posted by More on June 30, 2002 at 23:40:34: | |
| In response to Re: Water pump and presure tank WHAT PROBLEM? | |
What problem remains? The pump runs 24 hours and gets hot and blows a breaker? If the tank holds pressure, the pump should shut off as soon as it reaches the 40 pounds. If it doesn't shut off, then you need to adjust the high pressure side of the limit switch. If the small tank doesn't show 8 to 12 pounds of steady pressure,then the main tank is bleeding water through the small tanks diaphragm. Replace it. : I recently got elected to take over the maintenence of the irrigation pump set-up for our neighborhood association. It draws water out of an irrigation stream and is pumped to a faucet in each homeowners yard. It consists of a control box with overload breakers and fuses, a pump, one small presure tank mounted to the top of the pump and one large presure tank. Each fall the system is drained and shut off until spring. The large tanks bladder had broken a couple of years back, so it was a weekly chore to keep it aired up. This spring when I fired it up it would run about a day before quiting. The breaker would be blown and all presure in the big tank would be gone. I found a hole in the tank and replaced it. The problem remains. (although now the tank maintains air presure) Could the pump itself be the problem?
| There are none. |
