| Posted by Donna Gunyon on June 30, 2002 at 22:22:38: | |
| In response to Re: outside faucet | |
: : I have 3 outside faucets protruding through my brick home. they all gush water out the screw in the center of the handle. it gets much worse it I try to use a garden hose with a sprayer.what is the best way to repair these faucets.or do they have to be replaced? : - unscrew the nut and remove the stem of the faucet and you will see alittle rubber gasket on the bottom of the valve stem, replace this item and it will eliminate the water problem.
| There are none. |
