Re: Remove a broken PVC riser from a PVC tee
Posted by hj on June 30, 2002 at 22:09:52:
In response to Re: Remove a broken PVC riser from a PVC tee
As long as the riser was not glued in, any hardware store has a riser remover wrench to extract it.
: I have a underground sprinkler system in my lawn.
: A PVC riser was broken, which was connected
: a spray head to a PVC tee underground.
: The PVC riser is 1/2" in diameter.
: Now I have difficulty to remove (unscrew) the two
: broken pieces of the PVC riser from the spray head
: and the PVC tee, respectively.
: Could you you tell me where to purchase
: such a tool or how to remove the broken
: pieces?
: Thank you.
: Peter Xu
Replies to this post
