| Posted by Jyothi on June 26, 2002 at 09:52:44: | |
| In response to Re: Whats the best water softner for the money? THE RIGHT SOFTENER | |
: You came to the Right place. It seems you believe that you need a water softener, so the best advice is to analyze your water to determine what causes it to be hard, and also, what is suspended in it that you need to filter out. Ask your water purveyor for a water analysis, or go to GRAINGER at www.grainger.com for a water test kit (stock no. 3p991) or a Purwater test kit (stock no. 5UZ83). The Purtest kit has different parts for pesticide, or iron hardness, or Lead, or bacteria, Nitrate, Nitrite test analysis. Once you know what makes the water hard and what needs to be filtered out you can seek advice about the softener. Grainger has residential as well as commercial, so be VERY careful about asking for whats best for the money. If You are going to be servicing the system, you want easy access to the filters and isolation valves. If Culligan can install and maintain, you want quiet efficient operation. e-mail me if you need more help, after you get the analysis performed to your satisfaction. :
| There are none. |
