Re: are other Toto models recommended as much?
Posted by Terry Love on June 23, 2002 at 14:18:48:
In response to Re: are other Toto models recommended as much?
 : One of the many Toto toilets you recommend is tha Dartmouth, which : we like because of the traditional styling. However, in replacing : our current toilet, we want to go from one that has the handle on : the side to one that has the handle on the front, like the Toto : Promenade (TT-CST724) [which I think was called a Provincial until : recently]. This is because of the tight fit our current one has : and the way the side handle catches on the bathroom door. : Do you consider the Toto Promenade just as good? It has its handle : on the front, and so we prefer it. : A related question: we need a new toilet ASAP (we have a crack in : the tank in the current one), but hope to renovate the bathroom in : the fall. When we do so, we want to switch the location of the : toilet and the sink. Is there any issue with buying this new toilet : now if we want to move it for the renovation? : Thanks for your help! Timothy, The G-Max Toto like the Dartmouth will outperform the 2" flush valve Toto Promanade. The Promanade does work well though. Removing and reinstalling later would not be a problem. Your existing tank looks pretty bad. I wouldn't put any water in it. You could come home and find severe water damage if the tank gives way. Terry
Replies to this post
There are none. |
